Copying channels on the stagescape
Is it possible to copy all the stored custom settings ( eq, effects, gain, etc.) from one chanel to another one? Even from one scene to another.
For example: the main vocal chanel is good. But i need the same sound in different scenes. One scene with a complete band, one scene only with a small setup ( cajon, acc.git) one scene solo....etc.
But always the same eq, effects, etc.
Thanks for your answers.
To my knowledge, the key is to get the channel the way you want it then save it as a preset. There are instructions on how to do so in the manual.
However, you can't alter the "setup" using scenes.
A "setup" is a complete stage, ie the inputs assigned to whichever channels and presets you need.
A "scene" is a child of a setup and as such contains the same input assignments as its parent setup, however the scene can have selected channels muted or levels dropped.
Switching from scene to scene is instantaneous and causes no audible interruption to the performance (aside from the channel level and eq etc settings)
A setup change will load the alternative channel assignments BUT with all levels down. You should not really alter the setup during a performance (unless it is a change of band)
