judemichaels Posted January 11, 2015 Share Posted January 11, 2015 for Line 6 Musical Instrument Amplifier Line 6 StageScape md20 Pin 99-090-0105 Serial # (21) I have a line scape M.D. 20 stage Scape mixer ; usually when I turn it on it comes up with the stage set up last saved. Now when I turn it on the SAVED seen pops up and then Monitor B pops up. And nothing is plugged into Monitor B and if I plug a cord into monitor B input The icon in the input bar turns off, as if the sensor is switched to the opposite. Is there anyway to return to factory settings to reset that??? Quote Link to comment Share on other sites More sharing options...
dboomer Posted January 11, 2015 Share Posted January 11, 2015 Likely the sensor switch is stuck. This happens sometimes because all XLRs don't fif the same. You can free it by gently pushing it with a toothpick. You also may want to reach out to our support team at http://line6.com/support/ or search for your nearest authorized 3rd party service center here: http://line6.com/find/service_center/ Quote Link to comment Share on other sites More sharing options...
judemichaels Posted January 11, 2015 Author Share Posted January 11, 2015 I'll have to try that is their little switch or button inside the socket that you hit? Quote Link to comment Share on other sites More sharing options...
judemichaels Posted January 11, 2015 Author Share Posted January 11, 2015 Is there a button or switch inside there that you look for Anna guess you gently press it I'll have to try that thank you I'll see if it works:-) Quote Link to comment Share on other sites More sharing options...
judemichaels Posted January 11, 2015 Author Share Posted January 11, 2015 " all XLRs don't fif the same. You can free it by gently pushing it with a toothpick." I've noticed that lately that a lot of people are selling these LXR cables and they're so small what is the standard specs size for Line 6? that we should be buying? Seems to be it is not an industry-standard anymore? Quote Link to comment Share on other sites More sharing options...
Rick_Auricchio Posted January 11, 2015 Share Posted January 11, 2015 The Neutrik NC3MX male XLR connector has an outside diameter of 19mm (0.748 inches). Note that it's just a tiny bit short of 3/4 inch. They're high-quality connectors; when I have a flaky XLR on a mic cable I replace it with a Neutrik. Quote Link to comment Share on other sites More sharing options...
judemichaels Posted January 11, 2015 Author Share Posted January 11, 2015 Thank you so much I'll try all your knowledge tomorrow thanks again Http://judemichaels.com Quote Link to comment Share on other sites More sharing options...
