xe-la Posted January 25, 2015 Share Posted January 25, 2015 Hi, I'm after some advice about using the pod xt as a pre amp and connecting to a power amp. The pod xt only has unbalanced jack outputs but most power amps don't have these as inputs as they seem to be almost exclusively designed for use as part of a pa system. Has anyone used the pod in this way and if so how did you do it and did it work? Or is there a better way? Quote Link to comment Share on other sites More sharing options...
BillBee Posted January 26, 2015 Share Posted January 26, 2015 I've ran the ole XT into a variety of power amps with no problems. For an old Rocktron Velocity it was left to left and right to right, no issues there. I've also just ran the left out into the FX return on heads and combos with no problem. For PAs I've just ran the left out into the mixer and left the EQ flat. Hope this helps or I misunderstood the question :) -B Quote Link to comment Share on other sites More sharing options...
