mattkaine Posted January 29, 2015 Share Posted January 29, 2015 Everything seems to work fine except when assigning the expression pedal to anything other than 1. Wah 2. Vol via Line6 edit software. If I assign 1. Tweak 2. Vol both wah/vol LEDs light up on the pedal, the Expression pedal will adjust the desired tweak(stomp gain for example), but I am no longer able to switch to Volume to adjust volume. If I select 1. Wah/Vol 2. Tweak it behaves just as if it is set to 1. Wah 2. Volume, but will not adjust my set tweak parameter. The fact that both LEDs light up simultaneously when in 1. Tweak 2. Vol tells me something isn't right. Everything is current on firmware and otherwise seems to be working as expected. Am I missing something here? Is this not supported using what I have? I have tried everything I can think of. Thanks Quote Link to comment Share on other sites More sharing options...
mattkaine Posted February 6, 2015 Author Share Posted February 6, 2015 44 views and not a single reply??? I just want to know if I should be retuning my pedal board or living with the way it is. Someone has to have some kind of thought on the matter. Quote Link to comment Share on other sites More sharing options...
