Leadbritches1 Posted February 12, 2015 Share Posted February 12, 2015 Hi All Sorry if this has been covered. Just purchased Spider 150 and looking for a foot controller and saw the Firehawk FX. My question is there any point in buying the pedal board as the amp has all the effects so would it be a case of doubling up or should I just get a basic controller for the amp? I really like the Firehawk but not sure how much is covered in the amp. Your help is appreciated. Thanks Kris Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted February 12, 2015 Share Posted February 12, 2015 Looks like the Firehawk is the next generation HD500, so as such, it's a stand-alone device - you could use it with your amp, but if you are using the Firehawk's FX, then you would most likely only use a clean setting on the amp. Are you going to be using the amp live? Will you need to be able to change FX/sounds quickly between songs or during songs? If so, then you need a control pedal for it - either the FBV Express MkII or the Shortboard MkII. Quote Link to comment Share on other sites More sharing options...
