Sign in to follow this
james92789
spider iii hd150 help
so i just brought my first line 6 amp sounds great but i need to know is there a way of setting a preset to a channel cant find out anywhere to let me change faster
usually after you dial it in you just hold 1 of the ABCD buttons until it flashes and it will save your settings.
its been a long time since i had a spider III, was just what i remembered, must not be remembering it correctly, no other ideas and no longer have the amp... sorry .
I believe that after the particular assigned channel light flashes, you take your finger off the button & then push it one more time to lock the setting to that channel which stops the light flashing and then the settings are then applied to that channel.
