fflbrgst 1,844
Sorry, but you are mistaken on the way the looper operates on this amp. When you change the sound patch on your amp, the loop will change it's sound as well. I'm guessing you didn't realize it before you did the firmware update.
hi I have resolved the problem installing again the firmware, the effect memorized in the loop doesn't now change... I think that the memory of the flesh is modified if it suddenly misses the feeding ... thanks
problem to reply ..... resolved the problem installing again the firmware..
Sign in to follow this
Followers
0
hi I am Stephen from Italy, I have a problem with my amplifier spider IV 75.
when register a loop with a memorized effect any, if listening the loop and I change effect, the loop also changes, that is it doesn't maintain the select effect in phase of recording.
Before performing the upgrade of the flash, the memory of the loop was not modified.
the problem is independent from the use of the FBV SHORTBOARD MKII.
Is possible to find the original software to make a downgrade of the flash?
thanks for the help
