leesteel Posted April 8, 2015 Share Posted April 8, 2015 Is anyone using both of these together? If so, I would be interested in how you configured it. FX Loop? HD into M5? What about the midi part? If you set it up as an FX loop, and if midi in the HD can tell the M5 what patch to call up, then the loop can be located anywhere in the chain for any given patch. I anxiously await some advice. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 8, 2015 Share Posted April 8, 2015 i used to have that setup..... super easy! a couple of midi cables.... a couple of 1/4" TS cables and an insert cable (1/4" TRS to 2 1/4" TS) then just dial in the m5 and save your tone... next time you switch to that tone the m5 will go to that preset. surprisingly easy. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 8, 2015 Share Posted April 8, 2015 i used it primarily to take the reverb load off and free up the DSP... being that reverb was last in the chain it also freed up an additional block because the m5 can have the noisegate on too. once i was able to do the reverb independently on the DT amps, i didn't need the setup any more. 1 Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 8, 2015 Author Share Posted April 8, 2015 OK Zap, why a pair of TS AND an Insert cable? Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 8, 2015 Author Share Posted April 8, 2015 DUH, I see, TRS to LR for the send AND a pair of TS for the returns. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 8, 2015 Share Posted April 8, 2015 yes, only if you want to maintain stereo.. i assume it would revert to mono if you don't...(didnt try) Quote Link to comment Share on other sites More sharing options...
