Musicmannetje Posted June 30, 2015 Share Posted June 30, 2015 Hello, I have recently purchased a JTV69 which came without any sound in the modeling part. I have fixed that by upgrading the firmware. The problem is now that the positions 1 and 2 of the 5way selector switch are not working. In the 'analog' part, the switch is working fine. What should I do? reflash the firmware or have a look inside to see of there is a bad connection on the resistor-bridge of the pickup selector? Thanks! patrick. Quote Link to comment Share on other sites More sharing options...
Musicmannetje Posted June 30, 2015 Author Share Posted June 30, 2015 It turned out to be a grumpy switch. I reflashed the firmware but without any effect. Then (because it needed new strings anyway) took the scratchplate of and measured the resistance bridge. This proved to be good so I inspected the contacts of the switch, which were bad. Because it is a dual 5way switch, mostly used to switch the two tone signals (neck/middle) in a strat, the analog part does not have problems. It is somewhat disappointing that in such a guitar, a rather cheapy switch is used. I'm just going to replace the switch with a real one, see if that solves it. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted June 30, 2015 Share Posted June 30, 2015 Make sure you replace it with another dual 5 way. The analog is isolated from the digital. Quote Link to comment Share on other sites More sharing options...
Musicmannetje Posted June 30, 2015 Author Share Posted June 30, 2015 Make sure you replace it with another dual 5 way. The analog is isolated from the digital. Yes, I know, but thanks for mentioning it. I have build a variax transplant (a homebrew strat with the insides of a Variax 300 in it), and there I have used the switch in the same way. The 300 has a dual switch, with only one side connected. Quote Link to comment Share on other sites More sharing options...
clay-man Posted July 1, 2015 Share Posted July 1, 2015 Good luck! Quote Link to comment Share on other sites More sharing options...
stevekc Posted July 7, 2015 Share Posted July 7, 2015 Sparingly apply Caig De-Oxit to mantain working noisefree switch contacts http://www.sweetwater.com/store/detail/DeoxIT?adpos=1o1&creative=54989263441&device=c&matchtype=&network=g&gclid=CLHetNOzyMYCFQkIaQodE5MO3A Quote Link to comment Share on other sites More sharing options...
