gdaddy6 Posted July 2, 2015 Share Posted July 2, 2015 Could a momentary switch be used for expression pedal 2? I would like to use a separate pedal for tap tempo rather than the one by the volume pedal. I also control BPM's on a Timeline with the 500X tap via midi. If the external tap is possible is there a way to still control the Timeline BPM's via midi? Quote Link to comment Share on other sites More sharing options...
gdaddy6 Posted July 6, 2015 Author Share Posted July 6, 2015 No one? Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 6, 2015 Share Posted July 6, 2015 You can't use the EXP2 jack like that. You could use MIDI to control the tap tempo, though. Molten Voltage makes a pedal specifically for Line 6 products to do this: http://www.moltenvoltage.com/products/SIXY_by_PedalSync_Line_6_Tempo_Control_by_Molten_Voltage.html You could actually use any MIDI controller, though. You just have to program it with the correct CC. Quote Link to comment Share on other sites More sharing options...
