G70 ABC routing !!!
Can i use 2 amps at the same time without creating  ground loops, if you ever played with 2 amplifiers they usually create a ground loop when you split your signal and play both amps at the same time so i wonder if you'll get the same problem with the Relay G70 since there's no ground/lift button for the A/B outputs and the existent is only for the XLR output...
  • 3 weeks later...
