logixpro Posted August 3, 2015 Share Posted August 3, 2015 Good morning would the RC-3 Boss looper work best in the FX send/return on the spider valve 212 amp? Thanks Quote Link to comment Share on other sites More sharing options...
jossandeveiga Posted August 4, 2015 Share Posted August 4, 2015 Hi, i'm trying to use a digitech jamman delay looper with the Line 6 Spider Valve MKI, but connected through line in it sounds too low, and trough fx send i don't got that it works at all. Anyone can help me? thanks! Quote Link to comment Share on other sites More sharing options...
napynap Posted August 5, 2015 Share Posted August 5, 2015 Good morning would the RC-3 Boss looper work best in the FX send/return on the spider valve 212 amp? Thanks Since it depends on how you are using the RC-3, you haven't provided enough info to determine the answer (home, recording, live, etc..) . The SV 212 FX Send/Return is accessed on back panel Preamp Out (Send) /Power Amp In (Return) and doesn't appear to have any programmable parameters within any SV editing systems that I have experienced or seen in the documentation (onboard or software). It would work as a stand alone stomp box. I've used those jacks to lower the overall output, because the device I was using had a level control. Quote Link to comment Share on other sites More sharing options...
logixpro Posted August 5, 2015 Author Share Posted August 5, 2015 Since it depends on how you are using the RC-3, you haven't provided enough info to determine the answer (home, recording, live, etc..) . The SV 212 FX Send/Return is accessed on back panel Preamp Out (Send) /Power Amp In (Return) and doesn't appear to have any programmable parameters within any SV editing systems that I have experienced or seen in the documentation (onboard or software). It would work as a stand alone stomp box. I've used those jacks to lower the overall output, because the device I was using had a level control. Basically if I put the RC-3 looper inthe fx loop I can make use of the Internal effects on the amp when creating my loop. Quote Link to comment Share on other sites More sharing options...
