Matyrker Posted August 19, 2015 Share Posted August 19, 2015 Hey guys, just bought an XT Pro of craigslist. However I am having trouble getting started. I believe the unit is not reading my guitar signal. The signal light never lights up. I know that with my HD Pro there are various settings and switches that needs to be changed in order for a good guitar sound to come through. Just wondering if there are some hidden settings or something that I should make sure are working. Hoping that the unit isn't busted in any way. I have gearbox running, the software and the unit are communicating as well. If thats important. Thanks! Quote Link to comment Share on other sites More sharing options...
BillBee Posted August 20, 2015 Share Posted August 20, 2015 Its been a while since I fired up the ole XT Pro but isn't there a IO button on the front right? But a few things to try prior to going through all the firmware re-installation hassle would be: check the tuner for signal (should be the first thing a signal would hit), there may be a "input" jack in the rear of the unit (IIRC) in case the front one is bad, check the "pad" switch right side bottom, then try it with headphones. There are a bunch of options and hopefully its something simple. Hope that helps. B 1 Quote Link to comment Share on other sites More sharing options...
