Amp Parameters %
roberto_palitto
If you mean the amp DEP (mv, sag, hum, bias, bias x) and cab DEP (lo-cut, res, thump, decay) then Line 6 is aware of the problem and working on a fix, according to a support ticket I opened about this. But it's been quite a long time so who really knows...
If you mean the drive, tone stack, channel volume, and e.r. controls not showing their values, haven't seen that one and not sure what would cause that.
  • 1 year later...
Recently purchased a HD500x, did the firmware update & have the same issue. I found that if I select an amp higher up the list the sag, hum etc parameters appear then I could go back to one lower on the list eg a marshall & the amp parameters would remain.
Just a work around until line 6 comes up with a fix.
