Jacksc5 Posted September 2, 2015 Share Posted September 2, 2015 I've found that the xlr out doesn't produce sound when fx loop is activated. I would have liked to have firehawk connected to my audio interface and played through my amp too. Is there a way round this? Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted September 2, 2015 Share Posted September 2, 2015 I think that when you select amp mode the xlr's only carry mp3 playback from the app. You get guitar through them when your in line mode or direct or whatever it's called, check the manual it explains amp mode in there Not sure why the fx loop is affecting it though, I don't think it should Quote Link to comment Share on other sites More sharing options...
Jacksc5 Posted September 2, 2015 Author Share Posted September 2, 2015 I get that bit. I think it's also because my mix is set to 100%?? It would have been helpful to have the xlr out in amp mode so I could record without mic'ing my cab. Oh well back to the drawing board for me..... Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted September 2, 2015 Share Posted September 2, 2015 What are you recording into? I tried the xlr's into a usb audio device as I didn't want to bother changing the soundboard settings everytime I switched from recording guitar to recording vocals but I got a ton of latency and had to keep pulling the tracks back in time I found recording through the usb straight into the computer to be much better and I think all the other outputs of the firehawk still work as normal, the usb connection doesn't mute the other outputs Quote Link to comment Share on other sites More sharing options...
Jacksc5 Posted September 2, 2015 Author Share Posted September 2, 2015 Presonus i2 audio interface to GarageBand. Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted September 2, 2015 Share Posted September 2, 2015 Check my post above, I was editing it when you posted Quote Link to comment Share on other sites More sharing options...
Jacksc5 Posted September 2, 2015 Author Share Posted September 2, 2015 Thanks. Problem for me when usb connected it causes a ground loop and the amp fizzes. I think I'm on to a loser here. :( Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted September 2, 2015 Share Posted September 2, 2015 Are you using single coil pick ups? Quote Link to comment Share on other sites More sharing options...
Jacksc5 Posted September 2, 2015 Author Share Posted September 2, 2015 No humbuckers Quote Link to comment Share on other sites More sharing options...
