Robbsson2000 Posted July 19, 2013 Share Posted July 19, 2013 Hi all.. i found the trick with connecting the Boss FV-500L to the M5 for expression use. i soldered a cable with one mono to stereo connectors. on the mono side i soldered the "ring" to the tip.The cable is like this Stereo side: <Tip=Ring=ground==--------------==Ground=Ring&Tip> :Mono side With this cable the expression pedal works fine. 2 Quote Link to comment Share on other sites More sharing options...
margaretfoard Posted May 31, 2017 Share Posted May 31, 2017 I'm trying it (same Boos pedal) with a T/R/S cable on both ends. So far seems to work. WHy do you have to do the soldering thing? Quote Link to comment Share on other sites More sharing options...
