hgwest Posted September 12, 2015 Share Posted September 12, 2015 Hey All, in need of some guidance. I just bought a used (like new) Spider II 30w & FBV Express MKII for use in my home so I can leave my big rig where it is. The shop I purchased it from said the FBV Express MKII was completely compatible with the Spider II. My problem is, while the pedal will switch between channels A-B-C-D and the expression pedal does "wah" when you use the toe switch, the volume pedal itself doesn't work or the tuner. Any suggestions/ideas/recommendations? Thanks! Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 13, 2015 Share Posted September 13, 2015 the pedal is only a controller, it will only do what your amp is capable of. maybe the amp is limiting those functions because they do not otherwise exist? the pedal doesn't add anything that isn't already there. I don't have a spider II to reference... but i suspect that this is possibly what's happening. Quote Link to comment Share on other sites More sharing options...
hgwest Posted September 13, 2015 Author Share Posted September 13, 2015 I thought that may be the case with the tuner, but I figured at least the volume pedal would work. thanks for the info, never owned a Line product before, didn't know what to expect.... Quote Link to comment Share on other sites More sharing options...
