dudulu823 Posted October 10, 2015 Share Posted October 10, 2015 I already read the Line 6 manual, I think this is way out in manual : TAP - Tap tempo is available for all Delay effects, most Modulation effects, and some Filter effects. For Delay and Modulation effects turn the middle top row PARAMETER KNOB or for Filters turn the left bottom row PARAMETER KNOB all the way to max, and you’ll switch between tap tempo and regular control modes. Once you’re in tap tempo control mode, turn the knob to select one of the available note values. Tap two or more times on the TAP switch, and all the effects set to tap tempo control will change their time/speed/tempo to match the tempo you tapped. To end tap tempo operation for an effect, turn the knob to max again. NOTE: Parameters set to tap tempo control are not affected by expression pedal operation. I already try to turn the middle top row knob all the way max but the values still is ms, anyone can teach me how to solve this problem? thanks and cheers. Quote Link to comment Share on other sites More sharing options...
kenford Posted November 5, 2015 Share Posted November 5, 2015 Hey there, did you ever get your problem solved? I'm having the same issue....turning that button to max, but never goes into Tap tempo mode, but it only doesn't work in SCENE 1A, it works in all the other scenes....well anyhow, just wondering did you figure it out? Thx, Ken Quote Link to comment Share on other sites More sharing options...
afternoon Posted November 24, 2015 Share Posted November 24, 2015 same problem here... have to check that scene thing Quote Link to comment Share on other sites More sharing options...
rabbit-hutch Posted May 27, 2016 Share Posted May 27, 2016 have the same problem :( Quote Link to comment Share on other sites More sharing options...
bookieaka Posted September 26, 2017 Share Posted September 26, 2017 My M9 just got this problem after many years of use. After try many solution include factory reset, reinstall firmware, downgrade firmware etc. nothing solve this. So....my last resort, because my warranty ran out, I took off enclosure and clean the knob with " contact cleaner spray. " BOOM! My problem solved! every knob function as it should be again, knob can go to max and engaged tap tempo mode. **beware when apply cleaning spray, you shouldn't spray on the knob's pole, it will lose knob's friction that make it feel like cheap audio device! and also hard to fine-tune adjustment. Quote Link to comment Share on other sites More sharing options...
