Global Volume and USB
LesSand
When mixing in Reaper with the Helix as my USB audio interface, I find myself padding every preset patch by about +9db to make the level more compatible with other instruments (EZDrummer, primarily) in the mix. I'm OK doing fine adjustments in the mix, but since it's such a significant boost and consistently required across all patches, I'd rather pad it at the source.
I guess I could trim the inputs at the DAW, but I'm thinking I should do it at the source, not adding gain at a later stage.
Question: Is there a Global Level setting in Helix I could use with the USB output that I could use?
I thought of using the Global EQ Level setting for that purpose in the studio, but I read in another thread (and confirmed) it doesn't apply to the USB outputs.
-Les
