G70 how to edit?
ColonelForbin
I hope I just have a user error issue, hoping it's not hardware malfunction.. I am having problems editing on the G70 receiver! Pressing the 'NAV' button seems to do nothing, but rotating it does function. Where it prompts Rename?, I can't get anything to happen. I can rotate the NAV knob to scroll between, but pressing it to select or change a value does nothing.
Any ideas? I just re flashed the firmware on receiver and transmitter. Thanks!
I read some previous threads, where L6 states it's just an issue with the small plastic knob, and they have a replacement.
Needing a more immediate, albeit temporal solution, I just removed the knob and wedged a small piece of cardboard inside the knob post, allowing it to engage the button press properly.
I definitely can see the benefit of having multiple scenes, for a single transmitter. I set up three scenes, with -3 gain, 0 gain, and +3 gain. Basic clean boost, though it has a slight dropout when toggling from scene to scene. But definitely a useful feature for changing guitars with varying levels!
So, in the end, hardware issue, but simple fix. Could be worse!
  • 7 years later...
