audionutmike Posted November 2, 2015 Share Posted November 2, 2015 I have a preset with two ducked delays routed parallel then summed back together to give me a 2 tap delay of 250ms and 500ms. I know it's possible to program a foot switch to change the delays to 350ms and 700 ms, but I can't figure out how to do it. If it matters I have both delays on/off status assigned to a single foot switch. Is that the problem? Thanks in advance for your help. Quote Link to comment Share on other sites More sharing options...
GlennDeLaune Posted November 2, 2015 Share Posted November 2, 2015 Very easy to do. Just go to the delay settings at the bottom of the screen, press and Hold the Time knob and you will enter the controller assign function. From there just set your Min & Max values and assign the controller switch to the swtich you want. You'll have to do this for both delays since you're using two of them. 2 Quote Link to comment Share on other sites More sharing options...
audionutmike Posted November 2, 2015 Author Share Posted November 2, 2015 Awesome, thanks gangsterusa. I saw those parameters but was just trying to set a hard time on the delays themselves. I'll try it as soon as I get home. Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 2, 2015 Share Posted November 2, 2015 The other thing that you can do with the Helix in regards to delay time is assign note values for delay times and still have them controlled with an expression pedal or footswitch. So if you wanted to set up a delay that could toggle between 1/8th and 1/4 notes, you could. It's a nice feature that wasn't available in previous Line 6 products. 1 Quote Link to comment Share on other sites More sharing options...
