philrynhart Posted November 7, 2015 Share Posted November 7, 2015 Can any one advise if: 1. wall plates (xlr) are used between the M20D L6 link (AES/EBU) cable to the first speaker and between each L6 Link to each speaker will break the L6 Link and cause problems, we are considering using AES/EBU cable throughout but having wall plates so that cables are hidden because we are a church.. 2. the distance between all L6 link cables is less than 15mts as specified, but once installed we will not have any optin of analogue XLR connections, is this wise? 3. Finally referring to no 1 above, is it ok to join two AES/EBU cables using neutrik gold pin XLR's or does any join interupt the digital L6 Link and cause problems. Any advise welcomed as a matter of urgency, cables already laid behind the walls are all AES/EBU as specified for the L6 link connections. Thanks Phil M20D and 4x L2m 14mtr is the longest cable run and between speaker 2 and 3 in the system. Attached Thumbnails Quote Link to comment Share on other sites More sharing options...
