ultraknilch Posted November 23, 2015 Share Posted November 23, 2015 When using an external pedal to control for example the volume, and using the amp relay out to switch channels on my amp, the external pedal only controls a range from 0 to 78%... as soon as I disconnect the cable controlling my amps channel, the external pedal has a full range again (0-100%) Has anyone else discovered this problem? would be nice if you could try and see if your unit behaves the same way! Quote Link to comment Share on other sites More sharing options...
duncann Posted November 23, 2015 Share Posted November 23, 2015 Someone else came across this issue: https://www.youtube.com/watch?v=wePLttFDL4A Quote Link to comment Share on other sites More sharing options...
ultraknilch Posted November 23, 2015 Author Share Posted November 23, 2015 I wonder if thats a hardware problem.... a bleed from the voltage coming from the amps relay switch... Quote Link to comment Share on other sites More sharing options...
duncann Posted November 23, 2015 Share Posted November 23, 2015 Even if it is a hardware problem, I wonder if it could be compensated for in software. Quote Link to comment Share on other sites More sharing options...
