jasdadgad Posted November 25, 2015 Share Posted November 25, 2015 Is there a way to link two effects blocks such that when you turn one on, the other goes off? For example, I'd like to switch between two different distortions but don't want them both on at the same time. Touching one's footswitch would turn the other effect off. Thanks. Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted November 25, 2015 Share Posted November 25, 2015 Yep, select one block and assign it to a footswitch. Select another block and push BYPASS to turn the effect off and assign it to the same footswitch. Now the footswitch will turn one on and one off each time it's pressed. That same footswitch can do this with up to 8 blocks. Quote Link to comment Share on other sites More sharing options...
jasdadgad Posted November 25, 2015 Author Share Posted November 25, 2015 Fantastic. Thanks so much! Parenthetically, I've been on hundreds of guitar forums over the years. This one stands out - it's informative and it's polite. Great job, whoever's responsible. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 26, 2015 Share Posted November 26, 2015 Hi do you know if it's possible to make a footswitch switch off when you step on another one? Stu Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted November 27, 2015 Share Posted November 27, 2015 Hi do you know if it's possible to make a footswitch switch off when you step on another one? Stu Currently, no. However, there are a couple of IdeaScale submissions that address this. The first one is closed to voting and "In Review". It has 81 votes: http://line6.ideascale.com/a/dtd/Group-Switches-together!/779072-23508 The second one is still open for voting and sort of related to your question: http://line6.ideascale.com/a/dtd/Multiple-controllers-for-each-parameter-and-a-last-state/791302-23508 Quote Link to comment Share on other sites More sharing options...
Guest Posted November 27, 2015 Share Posted November 27, 2015 ok, thanks Quote Link to comment Share on other sites More sharing options...
