joeypinter Posted July 28, 2013 Share Posted July 28, 2013 hi, i'm recording in sonar x-2 with the POD HD plugged into the USP I can't seem to make the panning work, what i'm trying to do is have one guitar out of one side the other guitar out of the other side. what am I doing wrong?? Quote Link to comment Share on other sites More sharing options...
bjnette Posted July 29, 2013 Share Posted July 29, 2013 I use Sonar but am going via a MOTU 2408mkIII. When you insert an audio track, in the inspector pain click track and on the input you will have a list of available devices, You can choose left, right or stereo of the USB from the HD. You will now get left and right selecting stereo. On the same track Or you can insert two audio tracks and select Left and right input for each. If no joy check the patch you are using.By adding a stereo FX after a Amp block you should be getting stereo. Also look at the mixer levels and pans. Quote Link to comment Share on other sites More sharing options...
joeypinter Posted August 2, 2013 Author Share Posted August 2, 2013 thank you. do you know what BYP VOL means on the channel volume knob?? Quote Link to comment Share on other sites More sharing options...
