larsonea Posted December 6, 2015 Share Posted December 6, 2015 I recently purcase Sonoma Wireworks Riffworks standard. I have an amplifi TT and windows 10. I plugged in the TT and windows installed the driver. when I click audio setup in riffworks the tt does not show up. whay am I diong wrong? thanks 1 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted December 6, 2015 Share Posted December 6, 2015 I recently purcase Sonoma Wireworks Riffworks standard. I have an amplifi TT and windows 10. I plugged in the TT and windows installed the driver. when I click audio setup in riffworks the tt does not show up. whay am I diong wrong? thanks Did you plug in you plug in your TT, and let it start, before you open RiffWorks? Also when you were in the RW settings did you cliick on the drop down box for the ASIO choices? Quote Link to comment Share on other sites More sharing options...
larsonea Posted December 7, 2015 Author Share Posted December 7, 2015 when I click audio setup button it says riffworks is using the systems default audio device and the are no options. no dropdown box. I'm thinking riffworks is not seeing my TT as an option. don't know why. Thanks Quote Link to comment Share on other sites More sharing options...
Brazzy Posted December 7, 2015 Share Posted December 7, 2015 when I click audio setup button it says riffworks is using the systems default audio device and the are no options. no dropdown box. I'm thinking riffworks is not seeing my TT as an option. don't know why. Thanks Sounds like your right. Maybe you could try to reinstall RiffWorks now that you have the Line 6 driver installed. Did you check Line 6 Monkey to see if your up to date? Quote Link to comment Share on other sites More sharing options...
