Trouble Creating Dual Amp Patch
MGblade
i,ve created a great patch for my hd500-dt25, it,s a dual amp patch , channel A: plexi 100 brt , channel B: j-45 brt.
my problem is that channel B only works if i activate the effect right in front of the two amps, when turned of channel B stops working too so i only hear the plexi 100.
my chain is:   noise gate - tube drive - screamer -  boost comp - analog chorus - the two amps  - mixer set 100%L/100%R - delay - studio eq
any help apreciated
unfortunately that's not the case, the two amps don't have FS assignment,
I,ve tested it again with a new patch without effects just two amps (other) and again just channel A comes through, until I put an effect (any) right in front of the amps and turn the effect on.
Check your input assignment. If you have nothing in front of your 2 amps you need to select Same for input 2 so that your guitar signal gets routed to both amps. If you put a mono effect in front it will send its output to both paths and you should hear what you experience. If you put a stereo effect there you should have teh same problem.
Hope this is it,
Martin
