RPhil20795 Posted January 24, 2016 Share Posted January 24, 2016 Hey guys. Got a minor issue I can't figure out. Here's the situation. I use a Mission L6 expression pedal with my Helix to control overall volume exclusively. So volume block is last in the fx chain. I have found that when using a wah block, when I click the toe switch to engage the wah, it bypasses/shuts off the volume function of the Mission pedal. So the wah effect is insanely loud. The only way I could figure a way around this is to put 2 volume blocks at the end of the fx chain. So when I engage the wah, it bypasses one volume block and simultaneously turns on the other volume block. That's the only way it seems I can still have an overall volume control. This seems like it shouldn't be necessary, but I can't figure any other way. Any ideas? Quote Link to comment Share on other sites More sharing options...
capdoogie Posted January 25, 2016 Share Posted January 25, 2016 I'm having same issues Quote Link to comment Share on other sites More sharing options...
duncann Posted January 25, 2016 Share Posted January 25, 2016 When adding a volume block, it automatically assigns it to the EXP Toe. To get rid of that: 1. Select the volume block you want to remain on 2. Hit the menu button 3. Footswitch Assign 4. Turn the encoder until is says none Quote Link to comment Share on other sites More sharing options...
RPhil20795 Posted January 25, 2016 Author Share Posted January 25, 2016 Awesome. I knew there had to be simple solution. THANK YOU! Quote Link to comment Share on other sites More sharing options...
