Sign in to follow this
Jankomatic
Updating a Spider IV 75, Monkey can't see it
Title says it all, maybe I am missing something easy here.  I have a Spider IV 75 and a FBV Shortboard Mk2.  If I plug the USB cable into the computer from the FBV, Monkey can see it and lets me know everything is current as far as versions go.  Nothing I try gets Monkey to see the Spider IV 75 amp.  What am I missing here?  I have tried it with the power off on the amp and with the power on both.  I have uninstalled Line 6 Monkey, deleted all files and directories and rebooted.  So again Line 6 Monkey can see the shortboard, but it doesn't see the Amp.
Thanks in advance
Are you sure your CAT5 cable from the amp to the FBV is good?  (Does the FBV work with the amp?)
I'm having the same problem and i have a spider valve mk 212, is line 6 just dropping the support on these amps?
Same question I asked the OP (who never came back to report) - are you sure your CAT5 cable is good - does the FBV work with the amp?
