foodgeek Posted January 28, 2016 Share Posted January 28, 2016 Hey, I was setting my AMPLIFI 150 up as an amplifier for my new Firehawk FX board. I had both the AMPLIFI and the Firehawk FX paired to my phone and I was switching between the Firehawk app and the AMPLIFI app to set stuff up. I had set up a sound with no effects, no amp and no cam and it was working fine. Then I was steaming a song (to the AMPLIFI) to match a tone to that song, but suddenly I didn't get any guitar tone out of the AMPLIFI (but still the steaming music). I decided to cold boot the AMPLIFI, so I turned it off and then back on. After that the AMPLIFI was in Recovery Mode with the 4 flashing LEDs. I was not updating anything on the AMPLIFI at this point, only steaming music. Any idea what might have happend? Regards, Sune Quote Link to comment Share on other sites More sharing options...
douwevdheijden Posted February 7, 2016 Share Posted February 7, 2016 Having the exact same problem.. tried updating/resetting it about at least 10 different times, with both an ipad and laptop. Everytime I do it either doesn't work, or stays stable for a few minutes up to an hour and then reverts back into recovery mode. If you happen to find a solution I'm all ears :) Douwe Quote Link to comment Share on other sites More sharing options...
bbaron Posted February 8, 2016 Share Posted February 8, 2016 Do you mean that you are connected in the same time with one unique device (your phone) to your FH and your Amplifi ? I am not sure the BT protocol is supposed to support that. Have you tried to pilot your FH with one phone and your amplifi with another one ? Another idea would be to create a neutral tone and store it on your amplifi and to connect with your phone only to the FH. Quote Link to comment Share on other sites More sharing options...
foodgeek Posted February 9, 2016 Author Share Posted February 9, 2016 Having the exact same problem.. tried updating/resetting it about at least 10 different times, with both an ipad and laptop. Everytime I do it either doesn't work, or stays stable for a few minutes up to an hour and then reverts back into recovery mode. If you happen to find a solution I'm all ears :) Douwe Well, I fixed my problem by starting the amp in recovery mode (probably not needed but did it anyway) by holding tap and tone while turning the app on, then I pressed the bluetooth button and paired with my phone (i had previously removed the old pairing). Then I went to the AMPLIFI Remote and updated the firmware. That was it, it works again. Quote Link to comment Share on other sites More sharing options...
foodgeek Posted February 9, 2016 Author Share Posted February 9, 2016 Do you mean that you are connected in the same time with one unique device (your phone) to your FH and your Amplifi ? I am not sure the BT protocol is supposed to support that. Have you tried to pilot your FH with one phone and your amplifi with another one ? Another idea would be to create a neutral tone and store it on your amplifi and to connect with your phone only to the FH. Yes, they were both connected. It worked fine up until the point where the amp went into Recovery Mode. That was exactly what I was setting up on the AMPLIFI, a cabless, ampless setup to run the Firehawk through. Quote Link to comment Share on other sites More sharing options...
douwevdheijden Posted February 16, 2016 Share Posted February 16, 2016 douwevdheijden, on 07 Feb 2016 - 12:59 PM, said: Having the exact same problem.. tried updating/resetting it about at least 10 different times, with both an ipad and laptop. Everytime I do it either doesn't work, or stays stable for a few minutes up to an hour and then reverts back into recovery mode. If you happen to find a solution I'm all ears :) Douwe "Well, I fixed my problem by starting the amp in recovery mode (probably not needed but did it anyway) by holding tap and tone while turning the app on, then I pressed the bluetooth button and paired with my phone (i had previously removed the old pairing). Then I went to the AMPLIFI Remote and updated the firmware. That was it, it works again" -- Thanks, but I already tried this :( Quote Link to comment Share on other sites More sharing options...
holcomb Posted February 19, 2016 Share Posted February 19, 2016 same here I'm so frustrated with POS can any one help. It won't reset or come out of recovery. It was when I was trying to update it on PC. I borrowed a friend iPad still nothing..I'm 33 my wife just. Passed away . The only things keeping me hanging on is my 2 year daughter and playing music. Can someone please help Quote Link to comment Share on other sites More sharing options...
pranil007 Posted February 4, 2017 Share Posted February 4, 2017 THE Sokution is to hold the tone knob and the volume knob down and power on... Not the tone and tap button.. its all wrong everywhere. Then u may recover it through the software Quote Link to comment Share on other sites More sharing options...
