mikedaedalus Posted February 24, 2016 Share Posted February 24, 2016 Hey there -I'm noticing a very considerable difference in level when connecting via the g90 vs. connecting straight to the amp. This is detrimentally increasing the noise floor and causing a great deal of squealing and feedback through the amp. I've moved things around the signal chain and tried alternatives with gain structure and am confident this is not the issue - the only variable that seems to change output level is the line 6 g90... FYI: I'm not currently utilising the 'cable tone' setting on the g90. Signal flow is -Guitar> Line 6 G90> Line 6 Pod HD500x> Amp> Quote Link to comment Share on other sites More sharing options...
gpicard5 Posted May 21, 2016 Share Posted May 21, 2016 There is a gain setting in the unit which is most likely set really high as opposed to unity of 0db Quote Link to comment Share on other sites More sharing options...
feki Posted October 8, 2016 Share Posted October 8, 2016 Hi, I also had increased noise. Only in combination analog vs. Digital. I solved the problem of ground wire. The problem usually is in the galvanic isolation transformer - ground http://www.feki.hostuju.cz/imig/P_20160117_213334.jpg Quote Link to comment Share on other sites More sharing options...
