Indianrock2020 Posted April 14, 2016 Share Posted April 14, 2016 One more request for guidance before ordering and installing these: Dunlop SLS1031N Straplok® Dual Design Strap Retainer System, Nickel I have a strap and case on the way and I'm sure the strap isn't going to fit in the case. Walker & Williams G-26 Black Semi-Gloss Bullnose Guitar Strap with Padded Glovesoft Back Quote Link to comment Share on other sites More sharing options...
clay-man Posted April 15, 2016 Share Posted April 15, 2016 screws will be loose, and the screw on the bottom of the variax strap button is shorter than the other so it doesn't go into the electronic cavity. If you ever install new stap buttons, make sure you shorten the bottom one as necessary. Either way, I had these on another guitar, was going to swap it to my Variax and realized the screws were too thin compared to the stock ones. Tried using stock screws but it doesn't fit into the locking straps. Unless you use different screws, or do some modification, you're not going to be able to use those. Quote Link to comment Share on other sites More sharing options...
Indianrock2020 Posted April 15, 2016 Author Share Posted April 15, 2016 Has anyone found strap locks that will either work with the screws already in the JTV, or come with screws the right size? Quote Link to comment Share on other sites More sharing options...
