Marrissey Posted April 22, 2016 Share Posted April 22, 2016 Hi everyone I have done a patch with the Matchless amp clean and assigned the EXP2 as a expression pedal to change the Volume, Gain, Bass, Treble. Then I assigned EXP1 to the wah. I would like to have the possibility to use the wah with the Matchless clean, but everytime I hit the wah (assigned to toe control) the sound gets dirty because the Amp parameters change, following the EXP2 assignment. I tried to assign the on/off of the wah to a footswitch, but it doesn't work. Can you help me please? Thank you Quote Link to comment Share on other sites More sharing options...
k-grimm403 Posted April 22, 2016 Share Posted April 22, 2016 if you only want to switch between an A/B setting of the amp have you tried putting all the matchless changes on a foot switch or do you use settings inbetween? The reason the wah isn't working with the foot switch is that the button on the expression pedal doesn't turn it on/off, it switches between exp 1/2. So when you hit the regular foot switch it is activating the wah but the parameter is assigned to the wrong exp pedal and your still on the exp pedal that has the amp settings. if that makes any sense To get around this I would either try to set the A/B foot switch like I mentioned earlier or get a second expression pedal to assign it to. Quote Link to comment Share on other sites More sharing options...
BoneToner Posted April 22, 2016 Share Posted April 22, 2016 Exp pedal isn't on and off it switches between the two so try applying the amp settings to a footswtich, otherwise you'll have to get a second expression pedal for it to work Quote Link to comment Share on other sites More sharing options...
