nippyjun Posted May 16, 2016 Share Posted May 16, 2016 Hi. Is there an easy way to clear what a footswitch is assigned to? I can remove the blocks that the footswitch controls and that clears the footswitch but I can't seems to find how to clear what's a signed to a footswitch without doing that. And if there are more than one thing assigned to a footswitch is the clearing method the same? Thanks. Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted May 16, 2016 Share Posted May 16, 2016 Go into the menu and select Footswitch Assign. Use the joystick to go to the block you want to un-assign from the footswitch and rotate knob 1 below the screen until it says none. 1 Quote Link to comment Share on other sites More sharing options...
nippyjun Posted May 16, 2016 Author Share Posted May 16, 2016 Thank you. Quote Link to comment Share on other sites More sharing options...
chrisvermaak Posted December 28, 2016 Share Posted December 28, 2016 Thanks a lot. I could not find this in the manual. Quote Link to comment Share on other sites More sharing options...
vioreldodoc Posted October 22, 2019 Share Posted October 22, 2019 Easy way for me: Copy block. Delete block. Paste block :D 1 Quote Link to comment Share on other sites More sharing options...
