d0stenning Posted June 9, 2016 Share Posted June 9, 2016 nonchai 8:18PM in General Flag Hi - I plugged my iPad into a USB port on my iMac and used the OSX 10.11.5 Audio MIDI Setup utility to route my iPads audio output to my iMac's CoreAudio using "Show iOS Device Browser" . This is so i can play back audio from any iOS app thru my iMacs built-in outputs etc. But how can I now configure my Mac so that my HELIX ( plugged into the mac via USB ) can have its audio routed into the iPad so I can use Loopy HD as a looper in this setup ? Plugging the iPad directly into the HELIX works - but I need this setup to work too - since my HELIX needs to be able to be ( ideally ) permanently connected to my iMac while still being able to use Loopy HD from time to time without plugging and unplugging everything .... Any ideas ? surely this can be achieved without buying a iConnectMIDI box no ? Quote Link to comment Share on other sites More sharing options...
ricksteruk Posted June 9, 2016 Share Posted June 9, 2016 Have you tried creating an Aggregate audio device? that might work. think you do it from the Mac System Prefs sound section. Edit - no it's actually done from Audio MIDI setup.. in the Utilities folder with the Applications folder.. Still not sure if it will help though!! https://support.apple.com/en-us/HT202000 Quote Link to comment Share on other sites More sharing options...
