JeremiahEdward Posted June 12, 2016 Share Posted June 12, 2016 Does anyone else have the issue of the dim bypassed lights not working? For instance, when there is a delay assigned to a footswitch, it is brightly lit green when active, and dimly lit green when bypassed. My unit does not show any colored lights when bypassed. Only when engaged. So I have no idea what each footswitch does until I turn it on. If I engage that same footswitch, some fo the others light up (dimly) and varying colors... for instance, a few footswitches away from it will flash dimly red, then blue, then yellow etc. if I keep pressing any other switches (but they don't stay lit). A reset helped briefly, but it eventually display's the same behavior. I am running Firmware 2.00. Quote Link to comment Share on other sites More sharing options...
Kiari Posted August 17, 2016 Share Posted August 17, 2016 That is a setup matter. Go to setup (not scene setup) by pressing the switch "hold for setup" - at the bottom right from the right display, set "dim on". I strongly recomend to update the firmware to the 2.04 version. Quote Link to comment Share on other sites More sharing options...
