nguyen232 Posted June 30, 2016 Share Posted June 30, 2016 Basically i play rythm part of song. From time to time i need to play a kind of riff or solo. In this case i need to boost my sound. What is the best to acheive this for clean sound and for satured one. Quote Link to comment Share on other sites More sharing options...
ric1966 Posted July 1, 2016 Share Posted July 1, 2016 For a clean lead patch, I would start with your existing rhythm patch, copy to a new slot and add a red comp or blue comp stomp block, found under type DRIVES AND DYNAMICS. Fiddling with the sustain and levels controls should get you there. For an overdriven lead sound, I would copy my overdriven rhythm to a new patch and just adjust the volume slider up. You would then go back through all patches and adjust their volumes to get the right difference between rhythms and leads, as well as leads to each other. Quote Link to comment Share on other sites More sharing options...
AParedes Posted August 30, 2016 Share Posted August 30, 2016 this definitely works. another option would be to use the "Comp" as a boost - set the treshold to "0" andmove up the gain to the desired boost effect. this is also footswitchable if you are using an FBV3 or Shortboard Mk II. Quote Link to comment Share on other sites More sharing options...
