High frequency noise with G10
tochiro
The TRS male to TS female adapter solution means the RING gets connected to the TIP, since it goes from stereo to mono. So how can this work? The RING needs to go to SLEAVE, i.e. ground, not to the TIP, i.e. signal.
I have found that if I use a short extension cable (male TS to female TS), the noise goes away. Why does this work? Can it be the capacitance of the extension cable? Needs further research.
  • 5 months later...
  • 3 weeks later...
So, I might have found a solution for this high frequency noise. It requires a screwdriver, aluminum foil, electric tape and two hands. In my case, it came from the electronic of my bass, I guess. For this tutorial I assume you already have a shielded cavity, if not, DYI or bring your insutrment to a tech to do so.
Keep reading for the whole process, for the short solution scroll down.
I did the thing of swapping the ground with the sleeve, no result, with or without the Line6 adapter. This is the video of the issue I send to line6 supportNoise video
Sadly, the answer was: we're sorry, it is not compatible... Thanks for the effort line6.
So I asked the manufactor of my bass (the amazing Maruszczyk) and we talked about the noise, how it came out,so we made a test:
- Bass-->cable-->tuner pedal-->transmitter: no noise.
- Getting the transmitter close to the female jack: noise (see pic.)
So the transmitter is getting interference from the electronic (no noise in passive mode).
He then suggested to wrap the electronic with aluminum, which I did, checking for continuity. Sadly, this went bad, as you can see here Noise with shielded electronics
I started playing a little with aluminum foil and I eventually came up with the solution:
SOLUTION HERE
You can do the whole process with the instrument plugged in so you can real time hear if it works or something bad happens.
Step1
Take the female jack out of the cavity and put some tape on the outside of the tip pin (the one carrying the signal) so that the whole connector is insulated from accidental grounding (see step 2). If you don't do this right, you might experience no sound at all once everything is plugged.1.thumb.jpeg.f0672aef2d121255fb6269366497e6eb.jpeg
Step 2
Take a strip of aluminum foil and fold it 2-3 times so it gets a bit thicker. Wrap it aound the female connector. I made it large enough to touch the outer metal part of the connector and once inside the cavity to touch the inner shielding of the cavity. You can use some tape to ensure continuity. Again, in the whole process aluminum foil must not touch the hot wire/tip or you'll get no sound. Use insulating tape properly.
Step 3
The most effective. Take more aluminum foil (same 2-3 layers) and cover the inner hole as much as you can, leaving just a tiny space for the cables to get through. Use tape to ensure continuity between the inner cavity and the newly applied aluminum patches. Everything has to be connected for this to work. Try not to stuff aluminum too much inside the cavity, although doing this a little bit might bring better results. What you need to avoid, again, is for aluminum to touch the tip/hot signal.3.thumb.jpeg.b9f4e8050e33b2eac2ecd063fceb3222.jpeg
This is the final result. WIN
(I know, my amp is hissy, but I set treble and tweeter all the way up to maximise noise for diagnostic purpose).
Hope this helps other people, although you'll have to change the design a bit accordingly to how your guitar is shaped.
Cheers :)
  • 1 month later...
While a possibly useful post, I am not sure how this is related to clock signal getting to ground. An RF/EM inteference problem would be a different thing altogether.
  • 7 months later...
Here is an inexpensive solution to this problem: Mono TS male 1/4” to Mono TS 1/4” female. Using a TRS male to mono TS female did not work for me. Something like this will work although I made my own with premium parts:
1/4” TS to 1/4” TS female
I used this pouch to hold the transmitter to my strap:
Small Pouch with Clip
  • 1 year later...
I've actually discovered the POD Go is compatible with my old wireless transmitter pack from my G50 wireless system, so that's good as a stopgap. Bigger, not rechargeable, but functional and no noise. But Line6 really need to work out why this happens and fix it.
  • 3 years later...
Did anyone here ever try plugging the G10 power adapter into the same power source the amp is connected to? I had this same issue because my guitar rack and DAW rack are on their own power conditioner. I had the G10 being powered by the DAW’s power conditioner(MONSTER PRO 3500) because it has front access to utility outlets which are on round the clock. The guitar rack’s power conditioner(FURMAN PL-PLUS) has front outlet but it’s off until the rack is turn on. Once I connected the G10’s power adapter to the guitar rack, the high pitched background squeal went completely away. Only problem is I need to constantly unplug and plug the G10 into the respective outlets to keep it charged. Hard to remember sometimes.
