ColonelForbin Posted August 6, 2016 Share Posted August 6, 2016 Is it possible to have two different inputs for path 2? I'd like to feed path 2A from path 1A/B, and feed path 2B from the AUX input, or from one of the FX returns, like return #3. Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted August 6, 2016 Author Share Posted August 6, 2016 Yeah, I should just maybe search the forum before asking last years question! lol, I *think* this is the answer? Thanks Jaeger28! http://line6.com/support/topic/16292-adding-input-2b/ jaeger28 Posted 22 October 2015 - 01:36 AM Select the split node. Press action. Use the joystick to detach and create a separate input. Same with return and output. Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted August 6, 2016 Author Share Posted August 6, 2016 For what it's worth, I *think* this is what they are referencing in page 17 & 18 of the manual? 2 into 1 Move the Split block down to path B. The Split block shifts left and a duplicate Input block is created: This new Input block can be assigned to a completely different input. This routing can be used for mixing a guitar and vocal, or the models and magnetic pickups in a connected Variax guitar, each with their own processing blocks. True Parallel Move both the Split and the Merge blocks down to path B. Duplicate Input and Output blocks are created: In this routing, a guitar and vocal could be processed independently, each with its own input, stereo path, processing blocks, and outputs. Alternatively, two different band members could be processed independently. Quote Link to comment Share on other sites More sharing options...
