pearlfukinjam Posted August 10, 2016 Share Posted August 10, 2016 How do you change the exp pedal from Exp2 to Exp 1? I tried pushing down on the toe part, but it doesn't swap. There is a volume and wah in the patch. Using V2.0 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted August 11, 2016 Share Posted August 11, 2016 How do you change the exp pedal from Exp2 to Exp 1? I tried pushing down on the toe part, but it doesn't swap. There is a volume and wah in the patch. Using V2.0 As long as you are pushing down hard enough it should be swapping. You may want to double check the volume and wah block and make sure they are assigned to EXP 1 and EXP 2. Also, keep in mind that in the 2.0 firmware if you switch to wah and do not return to the volume block before you switch to another snapshot the expression pedal switch loses context and does not function properly. Quote Link to comment Share on other sites More sharing options...
