flannelcombat Posted August 11, 2016 Share Posted August 11, 2016 I have a question about recording with the POD 2.0. I currently have a setup that allows me to record from the amp directly to the computer via USB cable. I also use headphones when I'm recording due to not wanting to upset the neighbors. I use Audacity and I'm able to hear drum/backing tracks in the headphones as I record along with them. I just wanted to know if this was possible with the POD 2.0, and if so, how would I go about setting that up? I've grown dissatisfied with the hi-gain tones of my amp and would like to check out what the POD 2.0 has to offer. Quote Link to comment Share on other sites More sharing options...
BillBee Posted August 11, 2016 Share Posted August 11, 2016 Hey there, as you probably figured out you are going to need an audio interface for which to send the Pod's signal into so the DAW can pick it up. If your amp that does have USB out has a FX loop you might be able to go into there with the Pod the use the amp's usb to Audacity. Hope that points you in the right direction. :) Quote Link to comment Share on other sites More sharing options...
