Sign in to follow this
skramevets
Controlling volume when using wah on fbm mkii pedal
I recently wanted to use the wah function on my fbv mkii pedal.  when you press the foot pedal to change to wah the volume is at max, only way i see is to run to amp and turn down master (preferable to do that first i found out at recent band practice when i deafened the guys).  is there a way to set it up to default to a volume when using the wah function.  if not i think a separate wah wah may be in order.  Thanks
Normal amp operation would have the volume pedal at full (as adjusted at amp) volume when the toe of the pedal is all the way down.  If you use it differently, then you need an expression pedal added to your FBV set up to use as a wah, or a separate wah pedal to use between guitar and amp.
another potential option would be to use an external expression pedal (i.e. Line 6 EX-1 or Mission Audio), but you would need a shortboard for that (not sure what you are currently using).
