bvgration28 Posted August 27, 2013 Share Posted August 27, 2013 Could somebody please help me.... Ive had my JTV-59 since October and it worked wonderfully at first. Now I am having some problems with it and im completely stuck on what to do. First I noticed the bridge making an odd noise ONLY through the Variax Pickup system... NOT the passive. It sounded like a metallic noise. which i narrowed it down to the Low e string while palm muting....i also tapped on the bridge and heard the same noise through the amp. Then i noticed a Volume drop in the same string on all models especially on any clean/acoustic settings. I believe it has something to do with the saddle on that string because if i apply a little pressure over the saddle and string, the volume increases slightly.I dont know what else to do.... Im in desperate need of this guitar as now I based my whole Live show around it. Im oping this is something i can resolve at home and nothing i have to ship to be repaired. I would be willing to accept any and all opinions on this! Thanks Beau Quote Link to comment Share on other sites More sharing options...
ozbadman Posted August 27, 2013 Share Posted August 27, 2013 I haven't tried this, so it's total guesswork, however: Line 6 sells replacement piezo pickups. Therefore, you must be able to remove and replace them. I would possibly try swapping one of the other pickups with the one in the low E string and see if the problem persists. If it goes away, it's the pickup. If not, there's a mechanical problem. As I say, I've never done this or looked closely at the piezos. Maybe there's a more obvious problem like a bit of grit under the string, or piezo, or something else. Quote Link to comment Share on other sites More sharing options...
johnnyayyy Posted August 27, 2013 Share Posted August 27, 2013 Could somebody please help me.... Ive had my JTV-59 since October and it worked wonderfully at first. Now I am having some problems with it and im completely stuck on what to do. First I noticed the bridge making an odd noise ONLY through the Variax Pickup system... NOT the passive. It sounded like a metallic noise. which i narrowed it down to the Low e string while palm muting....i also tapped on the bridge and heard the same noise through the amp. Then i noticed a Volume drop in the same string on all models especially on any clean/acoustic settings. I believe it has something to do with the saddle on that string because if i apply a little pressure over the saddle and string, the volume increases slightly.I dont know what else to do.... Im in desperate need of this guitar as now I based my whole Live show around it. Im oping this is something i can resolve at home and nothing i have to ship to be repaired. I would be willing to accept any and all opinions on this! Thanks Beau The Tyler piezo bridge is junk IMO, poorly designed and even more poorly manufactured I am really hoping GraphTech or someone else will step up eventually with a nice no mod required replacement option. Oh, and my bridge makes lots of crazy noises too. Currently looking for a good fix. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 27, 2013 Share Posted August 27, 2013 My JTV 69 bridge seems to be just fine. I would prefer more of a Strat design that would accept a Graphtech saddle like the earlier Variax. I replaced the saddles with Graphtech on my 500 and the sound was improved over the original piezo's. Quote Link to comment Share on other sites More sharing options...
