StuMur Posted November 29, 2016 Share Posted November 29, 2016 Hi Guys, I use my M20d mixer at gigs that go from just me and an acoustic guitar (so just 2 input channels), right up to a 6-piece band that utilizes all 18 input channels. I always just use the same scene that is all our 18 channels for the main band eq'd etc the way I like it, and I just plug my 2 solo channels in to my usual gt & vox channels. But when I record even just a solo gig using 2 channels only, all 18 channels are recorded by default, as that's what that scene uses. Is there a way I can switch off the other 16 channels from being recorded? My 32gb card fills up fast when 16 silent channels get recorded too for every song! I even tried muting the 16 channels individually, which of course made no difference. I'd rather not set up multiple scenes etc just for a few different gig sizes, as often I do solo songs during the full band gigs, but I presume that's the only way? Any suggs appreciated. Thanks very much. Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted November 29, 2016 Share Posted November 29, 2016 It is as you suspect.. If an input channel has been defined, a recording is made of that channel regardless of its state. The only solution, and it probably isn't a solution for you, is a separate "setup". Might work for your solo gigs, but I doubt it's an option for your expanding lineup gigs. 1 Quote Link to comment Share on other sites More sharing options...
StuMur Posted December 4, 2016 Author Share Posted December 4, 2016 Thanks SiW, no probs, will just make a quick separate setup for it. Very easy. :-) Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted December 4, 2016 Share Posted December 4, 2016 Just remember that with a new setup, and swapping between them,. that the main levels (master and monitor outs) are set to -infinity when the setup is loaded, so it wouldn't be an appropriate solution mid gig. 1 Quote Link to comment Share on other sites More sharing options...
