How to disable Firehawk?
Manei123
The "no amp" selection can be found in the "clean" amp types. It defaults to "no cab" and has a volume setting for leveling with your other patches. Depending on your goal, you may also want to try the tube pre-amp in lieu of no amp, which also uses no cab modeI. I would only suggest that if you are going into a solid state amp with guitar speakers for monitoring.
