MaxDread Posted December 6, 2016 Share Posted December 6, 2016 Hi all For a long time know I have had my POD XT Pro connected to my soundcard breakout box via analogue (I've got an EMU 1820M). The breakout box is out of action at the moment, so instead I have connected the POD to the SPDIF PCI card inputs and outputs. I then set the POD to "Format - Match SPDIF" on the digital out screen, and "DIGOUT - SPDIF" on the Global Options. All works great.... Until I turn off the POD and switch it back on again, at which point I get the message in the thread title. It's not the end of the world. I can navigate to the digital out screen and change Format from "44.1kHZ / 24 Bit" (which it defaults to) to "Match SPDIF" and all is well again. Until I next turn it off. Is there any way of sorting this out so I don't have to do that every time I turn the thing on? Many thanks Max Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted December 7, 2016 Share Posted December 7, 2016 Try this: In the PatchMix DSP software find Session Settings>System and set the Internal/External buttons to External. With digital you have a master/slave relationship and I seem to remember that the Pod can only be a master, so the Pod acts as the master digital clock. Therefore the EMU will have to be the slave: hence setting the card to External. I would set the Pod's settings to what you want rather than Match SPDIF. Also make sure to use proper SPDIF cables (75 ohm), not just regular phono jacks. Quote Link to comment Share on other sites More sharing options...
MaxDread Posted December 7, 2016 Author Share Posted December 7, 2016 Hi Guru Thanks for that. It will be interesting to hear from anyone (or even someone from L6 directly) whether it is the case that the POD can only be a Master and not Slave. To be honest, I'd suspect it is not the case because once I set the POD to Match SPDIF everything works perfectly. So the issue is not so much whether it can work in that set up, but rather why it comes up with message each time I turn it on. Aside form that, I have the EMU connected to a Lavry DA10, and that can only be a Slave, so the EMU really does need to be master. As for cables, I do need to get something proper. But what I'm using at the moment is working fine. I'm cheating a little by using BNC cables with phono style adapters at each end. It's Neutrik and Van Damme so good quality, but I think it would better not to use adapters in the long run. But for this problem I'm having, I don't think the cable plays a part. Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted December 9, 2016 Share Posted December 9, 2016 I just dug out the manual and I read that by using Match SPDIF it says the POD will slave to any digital gear - so I guess it is acting as a slave. I just seem to remember that when I used my Pro digitally back in the day I could only get it to work as master, slave never worked properly for me, but maybe my memory is playing tricks on me. Quote Link to comment Share on other sites More sharing options...
