dannepop Posted December 19, 2016 Share Posted December 19, 2016 Is it possible to get a global volume pedal without making an object in the chain? When having an object in the chain it always saves the current volume setting. Having problem with this sometimes! Perhaps I get used to it! D Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted December 19, 2016 Share Posted December 19, 2016 Is it possible to get a global volume pedal without making an object in the chain? When having an object in the chain it always saves the current volume setting. Having problem with this sometimes! Perhaps I get used to it! D This situation is easily remedied. If you have the floor Helix you can use a volume block in any preset and set the Global Settings --> EXP Pedals --> 'EXP 2 Pedal Position' parameter to 'Global'. This will allow the Helix's internal expression pedal to correspond to the current position of your expression pedal in any preset rather than a saved preset value for the volume block. External volume pedal options would include using one in a send/return or in-line before or after the Helix. Ultimately I think what you really want though is just to change the setting I referenced to 'Global'. This should configure things the way you want them. 1 Quote Link to comment Share on other sites More sharing options...
dannepop Posted December 19, 2016 Author Share Posted December 19, 2016 Great! That was what I needed! D Quote Link to comment Share on other sites More sharing options...
