krigslida Posted December 26, 2016 Share Posted December 26, 2016 Hi.I have a some questions regarding the quick looper on the 120/240 Spider V.Can the loop be saved and later recalled for use?Can the drum beats if used also be used in the loops?Are there any limits regarding how many loop layers I can use?BR/Dan Quote Link to comment Share on other sites More sharing options...
ADBrown Posted January 4, 2017 Share Posted January 4, 2017 A loop cannot be saved and recalled for later use.You can record a loop while a drum beat is playing, but the drum beat is technically not a part of the loop.You can overdub layers on a loop, I'm not sure on limit. I believe after a very high number overdubs on a loop before the older layers drop in volume under new overdubs. Quote Link to comment Share on other sites More sharing options...
Guest Hux Posted January 4, 2017 Share Posted January 4, 2017 You can stop the recorded loop from playing by a quick double push on the function button. And then start up your recorded loop again with a single push. But the recorded loop is deleted when you turn off the amp. I don't think theres any way to save the recording in the amp for later sessions. Quote Link to comment Share on other sites More sharing options...
aboutpurpose Posted February 26, 2021 Share Posted February 26, 2021 Thanks for the tutorial on using the Looper. Once I have recorded a loop I like, how do I save that loop onto my computer or android device? Quote Link to comment Share on other sites More sharing options...
