capdoogie Posted January 2, 2017 Share Posted January 2, 2017 I posted this also on the fh1500 forum but no responses. Does anyone know if the internals of these two units are the same, outside of the power amp portion on the fh1500? If you were to not run the speakers of your fh1500 and run it thru FOH. Then compare it to a firehawk fx floor pedal. Would they be the same with same exact preset. I've been running my fh1500 with internal speakers off thru my new clr neo Mkii and it sounds better. So I was thinking just running the firehawk fx instead if it is same processors, etc. Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted January 2, 2017 Share Posted January 2, 2017 In theory they should sound the same, the 1500 does have more processing power but it isn't used for effects , the extra power is used for routing of the stereo signal when used in wet, dry, wet scenario. The firehawk fx cannot do this as far as I know but as you say you prefer the clr it shouldn't be a problem. 1 Quote Link to comment Share on other sites More sharing options...
capdoogie Posted January 2, 2017 Author Share Posted January 2, 2017 So in theory, my saved presets on my fh1500 should transfer to the firehawk fx? Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted January 2, 2017 Share Posted January 2, 2017 Yeah in theory, they use the same app so as long as the tones you want are saved to "my tones" on the app they will still be there when you connect to the firehawk fx, you will just need to put them into the banks/patches where you want them. Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted January 2, 2017 Share Posted January 2, 2017 Just make sure whatever output you're using on the 1500 is present on the firehawk fx, I'm not sure without looking but I think the 1500 had some extra outputs maybe? That's the only thing I can think of that might make it sound a little different. Quote Link to comment Share on other sites More sharing options...
capdoogie Posted January 3, 2017 Author Share Posted January 3, 2017 Perfect yeah I just use the xlr out Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted January 3, 2017 Share Posted January 3, 2017 So in theory, my saved presets on my fh1500 should transfer to the firehawk fx? Yes, the presets made on either unit will transfer to the other. mcbeddall nailed it in his explanations, just wanted to confirm the "in theory" part. 1 Quote Link to comment Share on other sites More sharing options...
