Sign in to follow this
Guest MikeCal
Can a Spider V 240 play a wired guitar + a G10T guitar at the same time?
Guest MikeCal
I know the Spider V 240 has a built in receiver for the G10T wireless transmitter.  When you've got a guitar connected with the G10T, can you have a second guitar plugged in to the normal input via a guitar cable?  Or does connecting via the G10T disable the cable input?
I'm looking for a way to connect two guitars to the amp when practicing with my son.  Yes, I know about inexpensive Mixers and ABY switches and even Y cables, but I'm considering getting the G10T anyway.  If using one allows a second musician to plug into the amp with a cable, that gives me another excuse to buy it.
While we're on the subject, does the G10T recharge by plugging into the amp somewhere, or does it come with a separate charger?
Thanks,
Mike
I suspect it's the same as the 60 which I have. When you plug in a second guitar via cable into the Spider V the G10T is no longer picked up. When you unplug the wired guitar it works again.
Guest mikecalligaro@hotmail.com
Thank you, Antmax.  Bummer, though.  I guess I'll just go with a cheap Y cable and not use this as an excuse to get a G10T.
Mike
Guest MikeCal
I went to my local Guitar Center today and confirmed that when you plug a cable into the Spider V 240 it disconnects the G10T.  Too bad.  On the good side, I confirmed that the G10T charges when you plug it in to the Input plug on the amp, though.  That's pretty cool.
Mike
